Warbleed
@$$hole
I am stating as a fact that as excursion increases, so does distortion. As excursion decreases, so does distortion, period.Read the first sentence in my post you quoted. Im not disputing distortion rises, although with BL optimized drivers the rise is very slight until things start breaking down.
If power really means nothing in how a sub performs (besides simply in output), are you suggesting its fair to test a sub like the XXX, Brahma or W7 with say 10 watts of power, then extrapolate that data to assume this is the driver's sound characteristics? Of course you would not.
Not getting full excursion out of the sub isn't just about not getting the full potential in terms of output, that excursion (or lack there of) does affect the sound of the sub. A subwoofer designed to run at 100 watts RMS can certainly sound 'better' than another sub, also playing at 100 watts, thats actually a superior sub but simply designed to run at 1000 watts or higher. Driver efficiency doesn't simply affect output, the 100 watt driver could likely deliver more output at lower octaves than the bigger/better sub, at 100 watts, again because the other sub isn't designed to move much at that power level.
Are you suggesting excursion, or lack there of, does not affect a driver's sound characterisitcs/performance? Only output?
Provided that you don't clip the amp, there is absolutely no reason why you cannot run a Brahma or XXX with 10 watts. They'd be able to produce more output than you might think at those power levels.
Seriously, you are on the losing side here man. Just give up. Research a bit and you'll realize I have yet to say anything that isn't 100% accurate, and 100% based on pure science. My opinion doesn't even factor into it.
It doesn't matter whether you are using 10, 100, or 1000 watts, the XXX will sound better than every other driver RE makes, period.
Why? Simple. It will have lower distortion at ANY power or excursion level, because it has more displacement and superior linearity at any excursion level.
This really isn't that complicated, I don't understand how so many people fail to understand such a fundamentally simple and obvious concept...this isn't even a debatable subject...logic, reason, and physics do not allow you to arrive at any other conclusion.
