Justintoxicated
Ok I have a couple questions for rear fill in a 05 Nissan Titan KC.
Working on Matting my rear Doors and I need to finalize what I am doing for rear fill.
1) Kenwood Excelon Dual Mag Mid
I already have these from my component set, I blew a tweeter hence why I bought the DLS Iridiums. I would only be hooking up the midrage from the component set and using the crossover to filter high frequencies. The would be run off HU power, I probably would not hear them much. This is what I am leaning towards. I'm also considering buying a new amp for my iridiums as I would like a little mroe volume from them, I was looking at the JL 450/4, these ocul later be run off an amp in mono.
??? Is it ok to use the stock speaker wiring to run off HU Power for the rear fill? Running new wires to the rear doors is really hard on my Titan KC, it can be done, but I need to plan it out in my next order from Knukonceptz if I'm going to run new wires.
2) DLS Coaxils.
If I run these I will probably end up getting a new & seperate amp, and wiring some kind of relay to turn them on or off to the dash panel. Or I can simply run them off HU power so they won't be nearly as loud as the fronts. However When using my Cd Player in advanced mode, I fannot fade all the way to front due to using Time Alignment!.
3) XXX 6.5's not sure if these will fit though, Might require some custom work, I think I can get 4.5 inches of mounting depth pretty easily, I might be able to squeeze another 3/4 inch over that.
These would be run off my existing amp and I'd have to buy another amp for the fronts.
4) Or recomend another midbass to run off an amp that will fit properly.
I'd prefer to only have 2 amps, so getting coaxils would require a 3rd amp to run the relay. I do have a mounting location for a small amp but it adds dificulty to the install.
2) DLS Coaxils.
