GCAdidas13
heh.
- Thread Starter
- #16
ThanksIf the back window is there, are you going to be able to put the subs in when it's done, or get a drill up in there to tighten it down?
good detail on the fan blades btw lol
I was actually planning on the box being a drop-in... probably not likely, but in that case I would be able to drop the subs into the box then put it into the car.
dimensions on the box are as follows:
externally:
height: average of 20"
width: 36"
depth: 15.5"
which would be around 5.5 cubes, and i'm going to do a decent amount of bracing as well as a double baffle if i feel up to it.
as far as bracing goes, halfway through the width of the box i'm gonna put a vertical piece of MDF on the whole cross section, and then same thing with half way through the depth of the box, while still allowing clearance for subs.
anyway i just had a revalation and won't have to worry about a darn thing about the fans. thanks anyway guys!
