reading frequency response graphs
Some loudspeaker designers are forced into that position when they work
for manufacturers. They want the cheapest drivers and they make you design
a crossover to make it sound acceptable. You are talking drivers that cost a few bucks
in some store bought product.
For DIY, there are folks who thrive on this. Lets get a cheap driver and try to make it
sound acceptable by making a clever crossover to fix issues.
For me, I just want to find a well designed driver that I'm able to plug into the amp
and have it sound good ''' as is "" without having to 'fix it' .. I pay more but the loudspeaker
is easy to work with and fine tune later.
For example, the 49 cent NSB. It need 6 cone treatments to fix gremlins. Also, a steep
slope helped alot to smooth out the sound. For full range duty, a phase plug mod helped
the top end. That is alot of work and modding for a 49 cent driver to make it very cool.
I even did coolant tests to boost power handling from 5 watts to 400 watts.
Plus, I had to sand the frames and paint it. Looking back, I'd rather tell the customer
to buy a $25 midrange because there is less labor to fix issues and you can focus more
on construction than driver mods.
i respect your opinion on that one, but at the same time i think its kinda kool that with a little elbow grease you can turn a 49 cent driver into something acceptable...so now i ask how do you do:
-cone treatments?
-a phase plug mod?
-coolant tests?
-cone treatments?
-a phase plug mod?
-coolant tests?
For NSB;
It's a paper cone so you can use chemicals to coat the paper. Some people use
certain diluted glue, some used polyurethance, I prefer spray can lacquer cause
it's thinned and lacquer layers meld with each other. I used a 1" paint brush to
paint the cone and dust cap, but not surround as it was rubber. Four - six coats
worked, let dry between coats. I did progressive coats and listened to the driver
and did blind testing to find the sweet spot on how many coats were needed.
Phase plug in this case was cutting out the dust cap and getting a $1.5 rocket
nose cone that fix inside, but it's hard to get a cone perfect so I got one with
a slightly larger diameter and used the drill to behave like a lathe, using sand
paper the diameter was taked down in thickness. Balsa wood is soft, each to
work with. It's too soft, touching the cone would cause a depression, so
I used minwax wood hardener and soaked the wood a few times. After it dries,
I cut the cone base to desired length. Paint it if you wish. To attach the phase
plug to the driver, you insert a flat head wood screw on the base, countersink.
The magnetism will hold the lightweight plug in place. Ideally, a phase plug would
be nicer if machined out of metal so it can act as a heatsink for the driver to
boost power handling a bit.
Coolant tests were ferrofluid injections. But the Ferrofluid I snagged was the
wrong kind for $30 a bottle. I needed the oil base, not water base fluid, but
that stuff cost $100. So, I added motor oil to the fluid. Power handling is
amazing with this stuff. Oddly enough, when 16 NSB's were used in the array,
driven by the 1200w, they handled the torture well and no coolant mod was
needed. I could add coolant if I wanted to make a line array for the sole purpose
of torture by allowing more SPL driven by a bigger amp. I was able to generate
insane midrange SPL with one driver with coolant, at 10 feet away one driver
would kill the normal person, imagine an array with coolant and more watts.
I don't think I would be doing cone treatments, phase plug mods and coolant
mods on $150 drivers.. /hehe
i think the only thing i would attempt would be cone treatments....seems cheap and easy enough, but how exactly does it affect the way the speaker produces sound?
PS i think i found my first project...my dad wants a line array...he likes stuff loud, SQ isnt TOO big of an issue, he just wants some new speakers for his big screen TV....it is gonna be run off of a mini system type thing, wattage unknown as of now...ill post up a new thread when i am sure i am gonna get it going...
Manufacturers spend alot of time making cone material and/or treatments, so
there is aot of testing done I would imagine. You do something, measure,
listen during driver development. But sometimes I wonder if manufacturers
really listen because the exotic cone materials the marketing people brag about
don't sound as good as they claim. My favorite sounding midranges are treated
paper, not those esoteric materials that create worse sound gremlins that you
have to fix electrically.
When you do your own mods you do controlled tests. Do a mod, listen. Compare
to an unmodded driver. Ideally, a switch to allow blind testing with a friend or two.
for drivers i am really hoping that partsexpress.com gets some more NSBs or at least a similary cheap driver, cuz i have heard good thigns about those projects....it is a two channel stereo....cabinet hieght isnt too important, but the TV is a big screen that stands about 5 ft high...so i would like em kinda tall...
jaygeorge1979
jaygeorge1979
Corpus Christi
jaygeorge1979
