reading frequency response graphs
let's just assume it isn't labeled correctly and it indeed is impedance. it is very similar as it starts flat, peaks, flattens then rises sharply. however, the graph does not line up with znom at all....
ok now i have another problem...i am finding multiple drivers that do not even offer these frequency response graphs...
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=297-076
all i could find is "Frequency: 20-5000 Hz"....is my only option here to play with my DCX and figure out where to cross it over? or would i be safe doing like an 8th order L-R bandpass from 20-5000?
My favorite sounding midranges had no published response graphs, yet
I was able to determine that they sounded better than other high end drivers
by doing in depth auditions. Later, I found some graphs on some of them
and they aren't pretty - but they are top notch in SQ.
Doesn't tell you much. Doesn't tell you it's SQ.
Run the driver full range to hear what it does 'naturally' out of the box.
Compare it to other drivers playing full range, you will figure out what it's
able to do.
Don't use that method.
One step at a time.
who in the mother of god told you that was a good idea?
i dont like your tone dave //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
well, i ASSUMED that since i cant see the graph, that something really REALLY ugly could be happening outside of that frequency range...my solution? have a slope so steep that virtually all frequencies outside of its recommended range wouldnt see the light of day...maybe i am wrong in my logic? please tell me
When you see a tweeter spec, not chart, that says 2000hz - 20khz frequency
range, that really doesn't tell you much. You don't know how it behaves betweeen 2000hz and 20,000 Hz. What if it has a steep roll off at 12khz? You'd
never know by that spec. You can look at the 2000Hz number and say "hmmm, perhaps it might work that low ? let me try it".
If you need a tweeter that plays low, down to 2000Hz and you find one
that says "5Khz - 20Khz", then it might be safe to say it won't do it well.
Same applies to midranges.
For woofers it's crazier. A subwoofer may have a 20hz - 1000Hz spec, but it
most likely will only perform well from 80Hz on down. Above that it probably
sounds like azz for many reasons.
you make good points...i am confused tho...what do you mean be steep rolloff at 12khz? how would you go about fixing a problem right in the middle of the drivers intended freq?
rolloff = drop in response //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
jaygeorge1979
jaygeorge1979
Corpus Christi
jaygeorge1979
