re xxx 3-way set-up ?'s
born into this
I wanna finally use my xxx mids... I was thinking bout doing a 3-way set up and using them for the bottom end, possibly just 2 way. need some help on matching them up with the right tweets (and mids if going 3 way). I looked up old posts already and was hoping there was some new info or experiences by some of you guys with them! not to mention I havent used an active set up in I dont know how long??? which ones would be good for a 2-3 way set up like im talking bout???any help would be great!!!
Well if you want to run a 2way setup. You will need a tweeter that can pick up around 2500hz. Ideally you want to keep the XXX6.5's below 1500hz to retain a smooth responce from them.
If you decide to run a 3way setup. Really any capable speakers will do. You will just need the right processing to do it correctly.
any suggestions for processing on the 3 way?
born into this
born into this
chicago
born into this
