RE vs Audioque vs FI
My car runs off the battery, actually. It just so happens that the battery has a nice charger for it: the alternator. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Changing nothing on mine but the battery improved my voltage quite a bit (with stock alternator).
80 Amp Alt, Yellow Top under the hood, and I was doing fine running my current set up.
Amps don't take a constant amount of power from the battery 100% of the time.
And if it does, it's not going to make a huge difference running 800 RMS vs 1200 RMS...
would the ssd with a flatwound coil set it apart from the sd2.5?? Im running 800 watts to it but i heard the flatwound coil not only increases power handling, but also output?
So tell me. What does your car run off of when it's running?
I would like to know.
More batteries provides more stability against sudden voltage drops...because there's more overall current supplying ability in the system. But going to a massive battery bank and not upgrading the alternator doesn't make sense because there needs to be a source of power to recharge the batteries //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i believe that fi and re are the same since one owns the other our something like that but audique is an awesome brand they're owned by digital design and my friend josh who does spl competitions is running 5 batteries and two hifonics goliath 5000 watt amps and he has a stock alt.
not sure what josh running 10,000 watts on a stock alt has to do with my decison, but alright. any other opinions are welcome
Daher2323
Daher2323
Marietta, GA
Daher2323
