Re-Using Sound Deadner
  • 7
Racerx250
Houston,Tx
I had the brilliant idea last night of since since i'm not driving my f250 anymore, why don't I remove the second skin from the doors in that and put it in my firebird. Is it possible? Will it have the same effictiveness? Is it easy/hard? Kinda need a quick answer.
btw it's SS Damplifier.
if you can get it off then i suppose you can. Or you can just not be cheap and buy new ones and have **** that would work well
//content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif that idea is not brilliant //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
dam n.
It sounded like a good idea in theory.
Maybe I'll try a little bit just to see if it will work.
Thanks for the quick responses.
i say don't waste your time and try it, you're just gonna end up pissed off and frustrated. Kinda like how your girl is after sex //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
My girl can hardly walk after sex //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Go give it a try...you will be back here in about 10 mins telling us how dumb your idea actually was. I could barely peel dynamat extreme off my doors after it was only on for about an hour.
Next time, use eDead. It just falls off for you. I'm starting wonder why ED doesn't just put this in the specs: eDead - the only deadener that will remove itself, so you don't have to. I think it's brilliant. //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
810
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
659
I own a 2016 Lincoln MKT. I purchased a FORScan chip to increase the power handling of my aftermarket speakers. However, I'm having trouble...
I hold firm on the deposit in all situations 😎
Brilliant ! - Thanks Doxquzme ...... that's exactly what I needed to know. Cheers !
Racerx250
Racerx250
Houston,Tx
Racerx250
    May 24, 2024
