Re Se10 Box Plans
Sn0rKy
all u box makin gurus
does this look right?
for a re se10
Box Parameters,
Vb= 1.833^3 ft
V(total)= 2.078^3 ft
Fb= 27.23 Hz
QL= 6.822
F3= 21.76hz
External Dimensions
10.96in X 26.25in X 16.81in
Slot Port
height 7.766in
width 1in
length 14in
and i have a question.. for the measurements, should they be exact or can i round up or down?
also where should i center the sub?
all u box makin gurusdoes this look right?
for a re se10
Box Parameters,
Vb= 1.833^3 ft
Fb= 27.23 Hz
QL= 6.822
F3= 21.76hz
External Dimensions
Slot Port
height 7.766in
width 1in
length 14in
mesaure as close as possible. always get as exact as you can. convert to millimeters and it will be eaiser to measure - and most people find that the sub\port facing the rear of the vehicle (using the trunk to reflect bass toward the cabin) makes the best sounding bass. other than that, just put it in the center i guess.. it dosnt really matter. just make sure that the END of your port is at least 1 inch from the wall... im guessing that the 16.8" depth is the side where your 14in port is going. so you are good.
i dont know if you will have port noise though. your port sounds kind of slim compared to its width... usually the rule of thumb that ive hears is a 1 to 8 ratio- for example, 1 inch tall, 8 inches wide. any smaller and you run the risk of port noise (the air rushing in\out making a funny noise on the edge of the wood, similar to a whistle)
otherwise it looks promising. and its cool that there is somone else on this board with a se10 //content.invisioncic.com/y282845/emoticons/thumbsup.gif.3287b36ca96645a13a43aff531f37f02.gif
my box was a little differnt. im doing 1.2 cubes as RE said, and my port was 9x1.5x13 i believe. so yours sounds quite close and looks good.
make sure you take some pictures and post your oppinions about the woofer. it sounds mighty good in my car.
good luck buddy!
//content.invisioncic.com/y282845/emoticons/popcorn.gif.32dd9e22fd77e77bc3c907062768fcd2.gif
Sn0rKy
Sn0rKy
San Francisco, Ca
Sn0rKy
