RE HC 15" cant find dimensions
  • 6
SirSyko
Delusional Psychotic
I just bought an RE HC 15" dual 2 ohm off ebay and now im trying to find some box dimensions for it. I dont even know the cutt out diameter for it, Ive never owned a 15. I drive a 98 stang and I always used sealed boxes because I liked how they sounded and because they fit easy. I would like to build a vented box, it doesnt seem too hard but I dont know if I can fit it and dont know if I will like the sound too much(I listen to rock). If the box is gonna be vented Id like to tune it low. I looked at the RE website and they dont have HC dimensions anymore, but I can see for the XXX they recommend 30 hz. So if anyone knows the dimensions for a sealed or vented 15" HC for SQ that would be some great help, thanks.
In my experiences with it, it's not a big fan of pretty small ported boxes...I'd say at least try and get 3 net, if not more.
Stay away from sealed...
if i remember right cutout diameter should be 14 1/8th inches...but i could be wrong.....
as far as i know all re's 15's use the same cutout diameter so you can check the site
ahhh whoops... well all i can remember for the specs is the Ported, which is 3.5. and i wanna say for sealed it 2.0, im pretty sure but not 100%. i have mine in a 3.23 sealed box and it deff is claen soundin
Man. We all have had our share of good and bad on here. Ive deff. had my share for sure.. LOL. It all works out in the long run. Excellent to hear...
398
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
Ive never seen this amplifier before. Can you take a pick of the back? Interesting amplifier.
problem was the LOC burnt out when I had touched cables. got a new LOC and now all is working. have to get the gain right, lights flickering with...
We still need to know what amp is having the issue, make and model. Some mono amps only have 1 preamp input and the other is a output.
SirSyko
SirSyko
Vancouver, WA
BIG_SUPERMAN72
    May 16, 2024
    May 16, 2024
