RE Enclosure Design?
Qbenjamin
Not sure how accurate that site's calculator is, but I am making an enclosure for an RE SX 10"
Driver info:
Mounting Depth - 6”
Mounting Hole Diameter - 9.25”
Overall Diameter - 11”
Bolt Hole Circle - 10.125”
Motor Width - 6.5”
Motor Depth - 3.25”
Basket Depth - 2.75”
Displacement - 0.15 cu. ft.
Electrical Q Value -Qes: 0.29
Mechanical Q Value -Qms: 4.3
Total Speaker Q Value -Qts: 0.27
Free Air Resonance -Fs: 30.7 Hz
Equivalent Compliance -Vas: 21.8 liters
One-Way, Linear Excursion -Xmax: 22 mm
Efficiency -SPL 1W/1m: 85.2 dB SPL
Effective Piston Area -Sd: 310 cm^2
DC Resistance -Re: 1.9 ohm
Nominal Impedance -Znom: Dual 2 ohm
Thermal Power Handling -Pe: 1000 W
Force Factor -Bl: 21
Alright, here's the info for my box......I calculated about 1.29CUF^ after displacement.
width: 20.25
height: 13.5
depth: 14.5
square port width: 1.5
square port length 1: 12.25
square port length 2: 8
total port length: 23.25
box volume (ft3): 1.44
__________________
1.29CUF^ @ 35hz - Does this look about right?
How did you come up with your box numbers? I input your info in BassBox 6 Pro program and it didn't like it. Unfortunately I don't have the RE SX 10 driver parameters in my driver database. e-mail or pm me if you have ???
Qbenjamin
Qbenjamin
Braavos
buildmeabox
