re-doing wall, any ideas?
anj46907
No Longer Truckin
for a while i was considering uprading my two 18'' BL's to something that can handle full potential from my PowerBass XA 4000D and subs that will be able to get higher on the meter from my current peak 151.3. im wondering if going up to the BTL's/MT's would do the trick, im also considering tearing the wall out and rebuilding it and doing four 15's just to have more cone area and still be able to get that powerbass amp working to its potential.
any ideas or input would be appreciated, and if any sub recomendations. my price limit on subs would be about $1500.00(hoping) but can definetly go higher if needed.
so far i have been considering
nightshades
HDC3
3515's
but again my budget can go alot higher if i find the right match
dang 49 hz //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif do 2 hdc3 18's 12 cubes with 4 6" aeros or a 220 or so inch slot port tuned to like 36.
Maybe it's just me, but 151.3 doesn't really seem very loud for a walled set up. I get almost that loud with a pair of 10" BL's. You can try upgrading to the BTL's, but they have a much heavier motor assembly and you might not gain much by switching over. You might want to try your idea of switching to four 15's instead. I run 4K too, and Fi recommended the BL's over the BTL's due to the limited amount of power I was planning to run.
um that doesnt mean yours sounds loud daily //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
anj46907
No Longer Truckin
anj46907
Bradenton, Florida
SPL Blazer
