RE audio
It is a mono amp. The amp has two sets of speaker outputs just to make connection of multiple subs easier - the outputs are connected to each other in parallel internal to the amp.
Wire the two positives of one sub to one of the positives outputs on the amp.
Wire the two negatives of that sub to one of the negative outputs on the amp.
Wire the two positives of the second sub to the second positive on the amp.
Wire the two negatives of the second sub to the second negative on the amp.
Yes. That is called parallel.
The formula for total resistance of loads in parallel is:
1/R + 1/R . . . . + 1/R = 1/R(total)
In your case -
1/4 + 1/4 + 1/4 + 1/4 = 4/4 = 1/1, so the end result is R(total)= 1 ohm
edit - 10 gauge is no problem. You can just jump the coils on the sub with 12-14 ga., and run a single 10 ga positive and a single 10 ga negative for each sub back to the amp.
your confusing me........ there should only be 1 neg/1 pos on each sub
No problem. Been there. When I think back to crap I did years ago, I am glad my family did not have a computer for me to tell people about it on forums //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
polarisfctyrcr1
polarisfctyrcr1
minneapolis
Brian Owens
