RE audio
how do i go about wiring it...it has two positive and two negative terminals per sub...can i just wire up one positive and one negative?
No, you have to use both. One pair of red and black is a voice coil. The subs are dual voice coil subs. Depending on how many ohms per coil, you can wire it to match your amp. Didn't you think of all this before buying them? Sounds like you need to read up on that stuff bro. i'm in MN too and could hepl but it wouldn't be until next week, but then again, that's when I'm starting my install:p:.
i dont no how to descibe it....like my w3's only have one positive and negative terminal per sub, the se's have one positive and one negative and then another 180 degrees around the sub theres another positive and negative.
thus dual voice coil
well i got 4 ohm subs, but arent interested in running them at that due to my amp, i wanna run my amp to 1 ohm even tho thats not the totally right way to do it. i was told that i just had to go positive frum amp to positive on sub negative to negative.
polarisfctyrcr1
polarisfctyrcr1
minneapolis
Brian Owens
