RE Audio MX12D1
subzero
RE Audio MX12D1 12" 1,500 Watts RMS Dual Voice Coil 1 OHM Car Audio Subwoofer
I was looking around for a sub that can load at 2ohms total and handle about 2000rms.
What do you think about this sub? what else is comparable or better than this?
I am thinking about a single sub setup. best options?
12" Competition subwoofer
Dual 1 ohm voice coils (This gives you the best wiring options!!)
(This is also available in dual 2 ohm voice coils in our store)
3000 watts peak
1,500 watts RMS rated
Tested and legitimate real world RMS power ratings
One-Way, Linear Excursion -Xmax: 22 mm (this is one of the highest excursion subs in our store)
Dual Composite 2-piece Cone
Rubber Surround
Integrated Gasket
Cast Aluminum Basket
Tork-Tite Terminal
4” 4-layer Aluminum Voice Coil
FEA Optimized Motor Structure
Powerful Neo Magnet
Dual Progressive Spiders
Integrated Tinsel Lead
Mounting Depth - 10.25”
Mounting Hole Diameter - 11.5”
Overall Diameter - 13”
Bolt Hole Circle - 12.25”
Motor Width - 8.5”
Motor Depth - 2.5”
Basket Depth - 7.75”
Displacement - 0.19 cu. ft.
Weight - 53 lbs.
Electrical Q Value -Qes: 0.503
Mechanical Q Value -Qms: 3.206
Total Speaker Q Value -Qts: 0.434
Free Air Resonance -Fs: 23.165 Hz
Equivalent Compliance -Vas: 59.0 liters
Efficiency -SPL 1W/1m: 83.5 dB SPL
Effective Piston Area -Sd: 480 cm^2
DC Resistance -Re: 1.4 ohm
Nominal Impedance: Dual 1 ohm
Force Factor -Bl: 14.56
Sealed Compact: 0.75 cubic feet
Sealed Optimal: 1.0cf
Ported Compact: 1.5 cubic feet tuned @ 35Hz
Ported Optimal: 2.0 cubic feet tuned @ 33Hz
i didnt like mine... i had four re mx 12 d2's... i just couldnt figure out a good box setup, though.
idk maybe a 3 cube box with 1500w and low tuning? or sealed box...
its a neo magnet, big deep basket and motor structure, and the mechanical noise when I inverted two of the four was pretty noticable (I'm not the only one who has reported that)... but you can give it a try. I traded two Orion 2500d's for the four, so that puts them at around 225ea value-wise...
they did great on the lows, but i just wasnt overall happy. you are a SS guy, I bet you could get an SPLX-HX 12 for less...
Coil options on the SPLX? I have only seen the D2 subs, remember i am looking a total load of 2 ohms @ 2000rms
ballsack lol they are dual 2's themselves... i had four T5 10's in my RSX and two SS XXX4000d's strapped @ 1 total, mmmm :-D doing a 150 at the dash with them was cool too
yeah, I have my t5's wired up at 2ohms. I could have ran one amp per sub at 1 ohm but then I have to worry about matching gains.. so I decided to strap the amps and drop the load on each sub to 1 ohm and series them at 2 ohms.
subzero
subzero
Chandler, AZ
RAM_Designs
