RE AUDIO DTS-1000.1 and 500.2 or PPI p900.5
bunnerrabbit
Trying to chose between these two. Thoughts? Already have the RE and the PPI is used but like new. Looking to power Pioneer TS-D1730C 6.75 components and a Shallow mount sub. Likely Shallow Pioneer 10" but considering others. X731BT head unit. Going on 05 Canyon 4 door.
If the ppi is only going net an additional 40$ , I'd go with that
I've used a amp that shares that same board.
The sub channel was stout enough for some nice impact also ran on a 10" at the time
and you can bridge the 4 channels for the components...tho probably unnecessary.
This way will be less install and amp locations ect ect...
so if 40$ isn't an issue go for it
I'll also add dont expect much out of that 10 shallow pioneer
Makes alot of sense here and good recommendation.Whats $40 bucks,especially knowing you will save space in a cramped environment already and have some power to go with it..Id run an American Bass shallow sub before that Pioneer if you havent purchased already,or look at a sundown or at the least a Kicker(since they have been around for over 20 years).The ony thing I have ever enjoyed from Pioneer since the late 80s to date have been the old GM amps,and a couple 1/2" tweets and HUs
bunnerrabbit
bunnerrabbit
Wilmington
audiobaun
