RD Audio D9
ricoshay
RD Audio D9
RMS power, 2 ohm linkable/dual mono
RMS power, .75 ohms mono 5400
RMS power, 1 ohm mono 3600
RMS power, 2 ohm mono 1800
RMS power, 4 ohms mono 900
Signal to Noise Ratio >100dB
Low pass frequency crossover 35Hz~300Hz
Subsonic filter 10Hz~60Hz
Bass boost @ 45Hz 0~18dB
Phase shift control 0~180 degree
Frequency response 10Hz~350Hz (+/- 1dB)
T.H.D @ 4 ohm
Efficiency @ 4 ohm 86%
Fuse rating 500 amps
Input Sensitivity 200mV to 6V (+/- 5%)
2 are gorgeous (9/10)...1 has scratches on top..7/10
all work fine
no trades
$850 shipped for pretty ones
$750 shipped for the other one
i have a matching 4 channel for additional $150
Ill check it out. I was actually on the site last week. Thanks!
219
if you can read a simplistic book you can follow the directions to put together just fine. Its not rocket science. If you have questions about the...
262
Well, I've owned probably over 100 different drivers in the last 40 years and almost every single speaker in the NVX line-up over the last 8...
16
677
ricoshay
ricoshay
Atlanta,GA
ricoshay
Doxquzme
    Apr 28, 2024
Doxquzme
    Apr 28, 2024
Latest topics
