RD Audio Alpha V1 12" (Parameters or Cutout Diameter)
The_Grimy_One
Phoenix, AZ
I just bought a 12" RD Audio Alpha V1. And I would like to know if anyone has the T/S Parameters of it, know the cutout diameter, and have a recommendation for a ported box giving it about 1400 watts RMS. An SQ based box.
Thanks for the help.
Thanks plenty. I will hit you up on some ?s. Gonna be putting it in my trunk. Should 2.3 cubes after all displacements @ 31hz, sound good? I want to get as much SQ from it as possible.
I have had mine in 2.25 cubes @ 32 and now have it in 2.5 cubes @35 and to be honest I could not tell a difference in sq but there was a slight difference in output going to the larger higher tuned box.
Thanks. And lastly, do you know the outer diameter? I will have to measure when it arrives if u don't, but I think I will double baffle the front.
How much port area should I do?
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
177
The_Grimy_One
The_Grimy_One
Phoenix, AZ
The_Grimy_One
    May 31, 2024
    May 24, 2024
