RD Alpha Max
I can repost it but I think mods would delete it again and dont want to get on the bad side of anybody just trying to figure out why it was deleted. I wasnt trying to sell anything just giving people a heads up on whats new coming out.
But yes very nice woofer.
Spl versions with the 12 spoke baskets are shipping now
The ground pounder versions with the new basket will be shipping no later than April 1st most likely middle of March.
The picture shown is a working sample the difference between this and the production model is the production model will have a magnet boot, flat braided tinsel leads, block terminals with two positives and two negatives on each side, black mesh on the side vents, Baskets will be metallic silver, and of course a spider ring.
They are 2500 watts RMS with the ability to be tuned into the low 20’s
Though they can low they still have excellent upper frequency bass like all our other subwoofers.
They fs on a 12” when broken in is 19hz\
The Xmax on these subwoofers is 22.5mm with a 65mm tall 8 layer flat wind
These subwoofers also offer our new linear coil technology that removes the risk of the coil rocking even at super low frequencies
We will also release t/s on the 12/15” within a week
The physical size of the motor is about 5/8” wider than the Alpha, it also uses the same strength magnet slugs as the Heavyweight.
The ground pounder version of the Alpha max is for daily applications or bass race it is not intended for SPL burps, If you want them for SPL burps you can choose the 12 spoke basket that still will sound very good in daily applications but will not go as low. It can handle 10-12,000 watt bursts.
The voice coil configurations available are the same as the HW for the SPL version and dual 1.0/1.4/2.0 on the ground pounder version
who the hell cares if you get on someones bad side if they are being a-holes to you, why would you give a f0ck!
The coil business is under wraps until next week once it is protected.
Basically it prevents the coil from rocking. Were as in the past you could build up eddie current and the coil could start hitting the sides.
In the past companies have opened there gap up alot or made they spiders very stiff. This is not the case for us. Now we are able to use one spider on subwoofers and put alot of power on them like 2-3 on the alpha max and the coil will never rock or leave the gap.
As time passes this will show up on the Sonance, Alpha, HW, and SHW
Of course on the SPL subwoofers we will still use stiff suspensions. But this greatly improves our daily/ground pounder versions.
Nobody's Louder
Nobody's Louder
Cape Coral, Tallahassee, FL
Papermaker85
vegang
vegang
