rca ?
hooking up 2 4 channel amps but deck only has 3 sets of inputs. 1 input is my sub and its in use so for my to component amp how will I connect them?
ok ur head unit has OUTPUTS... 3 of them, front, rear, sub..... unless there is a AUX in there more then likly going to be all outputs!!
1 should be labeld F for front
another R for rear
and last SW for sub woofer...
i have 3 amps one sub amp it using 1 of the 3 rca's (sub input) now i have my 2 component amps which are 4 channel which means i have i have to find a way to plug 4 sets of rca's into 2 outputs cause thats all thats available on my hu. dont know how to make it any simpler
2 options: y splitters for the RCA's or daisy chain the comp amps, simple as that //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
now we are getting somewhere! how do I daisy the comp amp and will this effect the adjustment and gains for each. they are both kicker kx350.4's that I just got dirt, dirt cheap!!
what are you doing with the 2 4ch amps??? one for front one for rear??
use rca splitters... at the back of the headunit.
and after all that if you still cant figure it out.... haha then have someone do it..
yes sethphillips I'm running my 4 6x9's off 1 for the rear and my 2 4x6's and 4 tweeters off the other for the front so what type splitters and how would I connect them. sorry if I seem like an idiot btw I'm just trying to learn becausei wasn't born a car audio expert
wish i was born one....
ur gunna need 4 1 male to 2 female rca' splitters....
one for front left ( red) one for front right (white)
same gose for rears. you plug them into the outputs of ur head unit....
take ur rca's red gose to the spliters that are in the red input, white gose to the spliter that's plugged into white....
come on now... if you dont get it from here.. i quit..
bigchevyboy
bigchevyboy
richtown va
danp129
Mike Mccabe
