new wires?
tdiddy
i just hooked up two new kicker comp VR15's to a kenwood KAC-9103D 1800 watt amp and i turned it on and it worked for the first 5 minutes and the amp shut off and never turned back on...i checked the battery and all the connections and they were all fine anybody have any suggestions?
no... the amp will turn on as soon as the cars turned on then it shuts off... i usually get sparks when i take the fuse out or something and theres no sparks now so im thinkin it might be the fuse box but im not sure
no... i used a brand new fuse when i put all of it in... but i used a bigger fuse then what i used before so i dont know if that did it or not i used an 80 before and then used a 100A
What load is the amp seeing? I had a kenwood amp that would do same thing if bridged @2 ohms. Get a volt meter and check.
The KAC-9103D is a monoblock amp and cannot be bridged //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Additionally it is stable at 2 Ohms.
Actually it is claimed to be stable at 1 Ohm though I have serious doubts as to the validity of that claim...
Does it shut off when you have no speakers attached? Also try wiring it to another sub or speaker. It could be a short in your subs. If not the amp is probably defective.
tdiddy
tdiddy
Arnold, PA
Stel
