RCA Out and Head Unit Amp
  • 2
Fixer64
Hello all at Caraudio. So... bit embarrassed about this question but here go's.
I have a Pioneer Head Unit and I have the RCA outs going to a 4 ch amp.
Can I use the head units (built in amp) speaker outputs to connect to extra speakers directly as well as using the RCA / Amp to drive existing speakers???
eg.
Head Unit RCA out to Amp + 4 Speakers
Head Unit Speaker out (Rear) to 2 Speakers. Or Front and Rear out to 4 Speakers.
Will it cause any issues. I have not found anywhere that says not to do it but still want to check.
Cheers, Mike
Simply put: not a problem.
The power amp and the low-level feed do no interact in a way that can cause problems if you use both, unless you try to run the SAME speakers off of internal and external amp.
Then you release the magic smoke.
Great, thanks very much. I hate the smell of that magic smoke - Smells like money burning.
This might be easy for some but i've only had it wired as a 4 channel. Theres a 2 channel to 4 channel switch and 4 rca's on the other side of the...
So you're planning on running active and using the amp or head unit crossover for the tweeters? Is that sub channel full range and have separate...
920
The black rca out is your mono sub output. That is the one you would use for signal to your sub amp.
This option is better because you need 3 pairs of RCA cables. Tweeters, midrange, and bass. You then use a Y at the amps on the Bass run, then use...
No make or model number on it? Do you have an exact picture of the rear and all its glory?
551
Fixer64
Fixer64
Perth Western Australia
Fixer64
slater
    May 2, 2024
slater
    May 2, 2024
