Featured Rca jack issue
Once you fix it, relax the shield ring on your cables a little. Some mfgrs think they need to have a death grip on the jack, and you end up with problems like this.
If the movement/vibration is causing the problem, use silicone caulk in the opening where the RCA outlets come out of the chassis. Let it dry overnight to see if that works. If not, your problem is internal, and you need to open the chassis. Sometimes, it is as simple as re-soldering a loose wire. Let us know how you solved the problem.
The problem was Amazon sent me a used amp that had been returned under warranty. It was missing screws from both face plates and 1 from the bottom cover. The sheilds fell off of both rca hook ups and were bent enough that they was not touching the ground circuit inside of the rca jack. Skar stepped up and replaced it for me. They sent me a new amp and didn't want the messed up one back. Thanks everyone for the suggestions on how to repair it.
That is good to hear.
Jay's ranger
CarAudio.com Recruit
Jay's ranger
N.b. Canada
Old_Slapper
vegang
vegang
