rca ground
no processor or amp should be grouning the RCAs....... the HU should be the only source ground in the whole system. 2 or more grounds in the signal chain will give you the basic "ground loop" noise problem--------don't ground it
i have no clue. is there some kinda old ass cable that had a wire running thorugh the shielding to pick up any electrical interferance and have it ground there? thats is all i can think of after reading the lil-note on the bottom of the pic.
i just bought those rca's you see in the pic. they have a ground wire(or thats what i think its for running down the middle of the 2 rca lines. The reason you can't see the ground wire is because i used it as the remote wire just for convinience and i had to peel it back so i could plug it into the other side of the amp.
Originally posted by tim-mania i just bought those rca's you see in the pic. they have a ground wire(or thats what i think its for running down the middle of the 2 rca lines. The reason you can't see the ground wire is because i used it as the remote wire just for convinience and i had to peel it back so i could plug it into the other side of the amp.
no----- that is a remote wire
ok, well good to know i'm doing things right then, and it's all working fine, it was just an inquiry question, thanks to all that offered help.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I'd do what you did. Use it as remote wire. I've heard of grounding rcs b4 when i see a page that is selling $120 rcas. Which have a brand name no one has ever heard of before. It's like saying oxygen free copper speaker wire. There is really no proven benefit to this.
hey dude, i used to ground my RCAs too, just the cable. but that was cuz there was a ground wire coming out from the RCAs. the RCAs i had was monster cable i believe.
i m not sure if this is wat u meant tho.
that is not a remote wire, most good rcas will come with a tag on that wire that says "do not use this wire as a remote wire" or something to that extent. that wire is meant to be grounded and is to prevent a whining noise, although most systems do fine without grounding it, but its not a remote wire.
?? I know Rockford Fosgate basic twisted RCAs have a smaller diameter wire in between teh two RCA channels, but that's actually meant to be a remote on, not a ground. This is all about the grounded sheath to the cable...
No make or model number on it? Do you have an exact picture of the rear and all its glory?
867
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
897
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
756
He'll be fine with any 4 ohm speakers, tuned properly. The focals are rated for 100 watts nominal and with the passive crossovers and power to...
848
Try this other test; get a 3.5mm headphone repair cable and connect it to the LC7i input. Connect that to your phone and measure. This will tell...
942
tim-mania
tim-mania
Tsawwassen, B.C.
ChefJoe
