RCA cables
crzybob77
I have somewhat cheap rockford fosgate RCA cables running to my amp. They cant be that bad considering they are rockfords, but i know that they are likely lowest in their line of cables. How much of a difference will it make to upgrade to a better RCA cable. Is it worth the money and the time installing? If i got anything, i would get the best knukonceptz RCA cables.
I agree. Just today I switched out some cheap RCA patch cables with some nice expensive magnovox gold plated ones. 4X the price; exact same sound. They will probably last longer...but the way my car is running...the car will die before the CHEAP RCAs would be able to corrode //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
f you don't have any noise now. Don't waste your time or money. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Originally posted by Eleazer My friend and I are Monster freaks. Although, only if you have very sensitive ears will the super high end expensive cables give their money's worth.
RRRRRIIIGGGHHHHTTTTTTT , you have them super human ears. That's cool that you can hear the difference between 2 cables. Given niether is defective
Originally posted by chris229 well if you HAVE noise you should trouble shoot with muting plugs THEN see if it was the RCAs
True. I'm just telling the man if it ain't broke don't fix it. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
No make or model number on it? Do you have an exact picture of the rear and all its glory?
632
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
614
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
564
He'll be fine with any 4 ohm speakers, tuned properly. The focals are rated for 100 watts nominal and with the passive crossovers and power to...
739
Try this other test; get a 3.5mm headphone repair cable and connect it to the LC7i input. Connect that to your phone and measure. This will tell...
865
crzybob77
crzybob77
Richmond, VA
ramos
    May 12, 2024
Brendon Jenness
    May 11, 2024
