Rattling...need help
jk123
OK, so i have my setup completed and it hits pretty hard....the only problem i have is that my liscence plate and my back tail light wont stop rattling when i listen from outside of my car. i was wondering if any of you guys have some suggestions on the best way to stop the rattling of my lisence plate and my back tail light.
thanks
you could try using foam or rubber stipping around it it would stop the rattle against the car also use silicone between the liscene plate surround and the plate itself that might work the foam stripping works on my car it stopped bouncing on the car cause it hits a soft surface just a thought
Audio Master
I stuck some peices of leftover dynomat, under the plate where the screws are, where it touches the body.
I think dynomat has a special license plate kit too.
i was thinking if you just tape your plate down,will look dumb but should work //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Or kill ur self.
Buy The Dynamat Kit
Sup Jeff? Using those 15's i think.
I used a sheet of deadener to cover the backside of the plate. Foam weatherstrip tape would work also. Pretty much anything that will make the plate bolt down tight.
Also listen INSIDE the car.....
jk123
jk123
Ohio
Fear Of Theive
