Ran into some problems. Plz help
Unscrew the end to get the endcap off.
Run that endcap onto the cable you plan on attaching to that end of the fuse holder. (threaded end towards the fuse holder)
Attach the cable to one end of the fuse holder and secure it with the Allen-head setscrew.
Screw the endcap back onto the whole affair.
Repeat this process on the other end.
//content.invisioncic.com/y282845/emoticons/word.gif.64b12e39f936af3b4fff38a1c0bd0244.gif//content.invisioncic.com/y282845/emoticons/thumbsup.gif.3287b36ca96645a13a43aff531f37f02.gif
It goes into the ends of the fuse holder and over the bare wires.
a lot of times there is a little rubber piece in there you are supposed to run the wire through...once you screw in the end of the fuse holder it locks that rubber piece in to keep water out....kinda see it? like a gasket? or am i not understanding what your talkin about?
unscrew the allen screw all the way... the little blue tube looking thing will fall out, its there for shipping purposes, after it falls out the wire will fit it nice and snug...
unscrew the allen screw and take the blue tube out then put the power wire in its place
I got it now. The blue thing fits so im putting it there. Its not in the pic. SO ya. Also one more newbish ? wut are the terminals for. I used one to connect the power wire to the batt. And i got 4 big ones left. 2 half circle ones and 2 all the way circled ones. And then i got 4 small halfway circle ones.
They go on the end of the wire, for your connections.
ohhhhhhhh, i thought he was talkin about the little grommets that keep the water out.......
so he is talkin about the little tube where the fuse would go.!
No im not talking about the little tube the wires go. You put your wires into this first then with the wire hanging out you put it into the little tube in the fuse holder. I think this is to keep water out. Any wayz wut happens if u have open wires and water touch them?
If the water doesn't bridge a connection over to some sort of ground, nothing.
Wrapping wires around the battery is no good, and by ground he means ground, or earth or negative, whatever you know it as. Anyways take one of the ring terminals you got and crimp it on the end of the wire than fasten it properly to the battery.
TheSpeakerMan
Knockin Pics Of da Wall
TheSpeakerMan
Conway, AR
qtipextra
