Ran into some problems. Plz help
TheSpeakerMan
Knockin Pics Of da Wall
Right now im connecting wire into the fuse holder. I got the wire thined out so it will fit into the fuse holder. Theres this blue tube i got into the fuse holder that u run the wires through. And if u move the fuse holder to get the other side on then the side thats done the wires fall out of the fuse holder. It is pissing me the **** x3424234234. Im beating up my car. Is there a easy way to get that. Im doing the best i can to explain my problem no plz help me.
1 more thing do i run the wire through a blue tube type thing or do i just run wire right into fuse holder?
Unscrew the end to get the endcap off.
Run that endcap onto the cable you plan on attaching to that end of the fuse holder. (threaded end towards the fuse holder)
Attach the cable to one end of the fuse holder and secure it with the Allen-head setscrew.
Screw the endcap back onto the whole affair.
Repeat this process on the other end.
TheSpeakerMan
TheSpeakerMan
Conway, AR
qtipextra
