Ram Crew Cab Sub Options
thegreat22
Hey guys I have a 4th gen ram crew cab. I would like to do some 8's ported under the seat. I mostly listen to rap,decaf, and r&b. Last boxes I had was tuned to 32,28, and 31 hz. Most of the pre fab boxes I found are sealed. So most likely custom fiberglass is the way to go. Anybody have options on what setup will be a good fit. these are the pre fab boxes I was looking at https://www.netaudiowf.com/store/dodge-ram-2/2002-2016-dodge-ram-quad-cab-sub-box-dual-tall/
and
DODGE QUAD & CREW CAB 2-10" VENTED
@CSCStang may be able to build you one cheaper, not sure if fiberglass is 100% necessary? is the shape of the back of your truck inhibitive of a regular box? he works with 8s and ext cab trucks a lot.
NET Audio is a Dodge Ram specialist. They're not selling pre-fab enclosures. I've had them make us a few truck enclosures as well as one for my car. They take a while to complete the order, at least they did in my experience, but the results are awesome. I had them make a fiberglass bottom enclosure for a '98.5 Ram extended cab when nobody else had anything worth buying. That turned out perfect for my client.
If the port is tuned in the mid-high 30s it will likely sound a bit louder than what you've had before. It depends also on the max air space and the subwoofers, as well as amplifier power.
I'm actually working on one for a customer right now. The bottom is fiberglass to utilize all the airspace possible. The upper part is MDF. I'm building it for 3 db drive wdx6.5 3ks. It will be ported and tuned to 37hz. I'll post some pics if your interested.
But ported is definatley the way to go imo
Any updates on your build
thegreat22
thegreat22
America
juan_caliente
