raised subwoofer rings
BreakMyWallet
wsup fellas.. gotta get my system done before show season and dont really wanna do the whole fiberglassing thing.. i was thinkin of just doing a regular sealed box but build up rings where the sub sits to make it pop out a bit. whats the best was to do that?
fiberglass?
would bondo work? i need something that will last and not crack ect
anyone has pictures of this?
thanks guys!
fuk you guys are fast.
not too good with specialty tools yet.. theres no way i can just make mdf rings and bondo it a bit do make it sturdy and sand it down smooth and cover in suede?
nvm i know what the jasper jig is. my router is fuked up tho //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
You could always do something out of Bondo, but if it's getting covered in suede then that's going to be an assload of unnecessary sanding if you just used a circle jig in the first place.
Could always just cut the circle with a jigsaw and then sand them , But if you decide to go the filler route, use reinforced filler //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Just fiberglass it. I assume you are talking about something like this
And maybe even adding a few rings on top of that to push the sub farther out. If this is the case then just screw a few more rings to the rings already in place AFTER you fiberglass the fleece then just do a few layers of fiberglass around it, followed by some bondo to smoothe it out.
im not concerned with cutting the rings.. just filling in the space from the raised circles to the rest of the box.
ahh okay , Slap the rings on and kitty hair that bastage. Sand the fark out of it with some 60-80 grit //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Or make the rings oversized and do a beveled edge that will taper down to the surface of the box and cover it and be done...
That would be the easiest way, but the op said he's not good with a router . I know there is a pilot bearing. Just going by what the man said //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
BreakMyWallet
BreakMyWallet
So cal
IamDeMan
AJ (ACE)
    Jun 28, 2026
