Quick RCA question
THIS IS WHAT YOU NEED TO DO
hook everything up. run the rca's from the line driver to the first amp. BEFORE connecting them, turn the radio on to whatever volume. check the volts at the rca end at the amp. make note of said voltage. turn everything off. hook the rca's up to the first amp. turn it back on at the same volume. test the output rca's from the amp to see if the voltage matches the first numbers. if so, it will work. if not, use a splitter
where did I say that feggot. I simplified what O.P. said so others could understand. JCO is not as mentally sound as the rest of us.
you shut your mouth when you talk to me //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
do this and /thread
BallinByNature
$Black Boy White Boy$
BallinByNature
So.MD
jco1385
