quick question
well I need some new rca's because when I unplug the White one which I think is the left I dont hear a change in loudness. When I unplug the red one and leave the white plugged in there is no music at all. I can't even tell you about how many Rockford Fosgate rca's I went through.
lets say i unplug my left RCA cable, arent I suppose to still here music from the right, or vice versa?
My fault this is wrong, I meant to say that if the left is unplugged then I should still hear music from the other and vice versa
no, unless its because I have a monoblock amp interconnects hooked into my 2 channel amp, which states rca "out(thorough)." I have 1 amp on each sub
Many 2-channel amps, in bridged mode, will only use the signal from the left or right channel input. Try hooking it up in stereo mode instead and see if one speaker keeps playing when you unplug each RCA
Yeah Ima try that tomorrow, My subs are 2ohm dvc, im tyrin to stay away from wiring this in 4 ohms sooooo. Im going to 1 v.coil from each of the 2 subs to my 2 channel amp. Then Im going to wire the other 2 v.coils in 4 ohm and hooked that to my monoblock amp, then hook my monoblock amp to my "subwoofer out" on my HU and the 2 channel amp will be hooked in the regular rca out jacks on the HU. As for the "subwoofer out" (monoblock amp) Im going to use this as if it was a Loud button.
If I'm reading that right (and I had to try three times) your subs are going to have each voice coil hooked to a different amp, wired for a different impedance load and connected to a different output on your head unit?
There is no possible way that's going to go well.
trigga_b
trigga_b
chicago
KaeZoo
