quick question about my set-up! need ur opinions/suggestions
Takedown792
ok so i have dual soundstream T4-15's in a sealed box running off a 1100 watt powerzone crunch amp. i have a feeling that my subs are way under powered. b4 i have 2 15" boss blades powered by a fury ssl 2000 watt amp an i only needed to turn the volume up to like 30. this amp i have now i need to turn it up to like 55-60. ive maxed out my volume b4 with perfect sound. i just know they can take more power then 1100. ill post my subs an amp specs an u tell me what watt amp i should get or any specific kind of amp u suggest that would be good for these subs. i know from videos that these subs are suppose to flex hard core but i get small ammount of flex meaning not much power.
Subwoofer Specifications
Subwoofer Size 15"
Voice Coil(s) Dual
Impedance (per voice coil) 1 ohms
Peak Power Handling 2000 watts approx.
RMS Power Handling 1000 watts
Woofer Composition Cloth Laminated Paper
Woofer Surround High-Arc, High-Excursion Foam
Sensitivity 91 dB
Frequency Response 20 - 1000 Hz
Xmax (millimeters) 14 mm
Top Mount Depth 8-1/4"
Cutout Diameter 14-1/4"
Amp Features:
PowerZone Series 2-Channel AB Car Amplifier
4 ohms: 225 Peak watts x 2 chan.
2 ohms: 550 Peak watts x 2 chan.
Max power output: 1100 watts x 1 chan.
MOSFET output power circuit configuration
Soft start sound
LED power and protection indicators
Tuned Bass EQ 0-12dB at 45Hz
DC, short, thermal, overload protection
Full range line output
Unbalanced input(RCA jack)
Variable input level control: 0.2V-5.0V
Illuminated Crunch badge for a clean appearance
Frequency response: 15-300 Hz
Dimensions: 13.38"L x10"W x 2.16"H
i have feeling im under powering these subs.
Get a line driver that matches the max voltage input of the amp.
Read up on line drivers and what they do.
You are not getting the most out of your amp, I can tell by the fact that you didn't mention the amp's gains or the head unit's pre-amp voltage.
DO RESEARCH!
Ok you just said the sub you are running is rated @ 1000 watts rms...you are putting like 200 watts or less to it...Doesn't that answer your problem?
(2 x dual 1 ohm voice coil subs can be wired to either 1 ohm or 4 ohms, since that amp is not 1 ohm stable it is running @ 4 ohms which is around 200watts rms per channel.)
Look into a 2,500 watt rms amp to power the pair of subs, and have it professionally installed/adjusted.
For reference your amp costs about $75 brand new....A 2,500 watt rms amp is going to cost about $500 used from the classifieds section.
"BUMP"
still idk if i should get a 2500 watt amp or a 3000 watt amp. what kinda amp would u suggest for these? i dont want to much power to blow em an i dont want to low power cause i dont want clipping.
"BUMP"
... what amps are you looking at, as i'm sure they aren't true 2.5k/3kw amps if they are in the same league as previous ones mentioned.
Takedown792
Takedown792
Painesville, Ohio
Takedown792
