Quick Orion Question...
BigDrez
Is the West Coast Customs 5000D the same as an Orion 2500D....somebody said the power is not nearly the same...only reason I ask is...is that on Ebay it says RMS rating is 2400 and the 2500D is 2500....which leads me to believe they are completely different....maybe they meant 2400 max and it is a little less powerful? I don't know...anybody else have any ideas?
Yes they are the same amp.
It even says orion 2500d on the amp in the lower right corner
Orion just puts different end caps and a badge on it for wcc.
And the reason for the raited power is cause the 2500d does not put 2500w
It puts out 23xxw
Yes they are the same amp.It even says orion 2500d on the amp in the lower right corner
It puts out 23xxw
ERRRRRR wrong, the 2500D does rated power. MINE did 23xx...with a 1.3 ohm rise.
lol where are you getting your information from?
and the WCCD5000 and the Orion 2500D are THE EXACT SAME AMP. use the search feature...its been answered 20 billion times in the past month alone.
never heard of the orion only doing 2300 watts //content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif but nyways exact same amp. you can even rip that badge off the front of the amp
Has the search function stopped working since the last time I posted on here ??
apparantly //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
and lets seep ics of that manual...even though every single one ive seen says 2500 @ 1 ohm....briiiiiing it on mr know it all.
BigDrez
BigDrez
Macomb County Michigan
SBLAZER
BP1Fanatic
    May 14, 2026
BP1Fanatic
    May 14, 2026
