Quick help with this wiring for these subs
Juicemane
2 dual 2 ohm dd9512g's hooked up to a dd z1a I'm about to switch it to run at .5 ohm but what ohm load is the amp currently seeing. Please see paint attachment. Would the amp be seeing 2 ohm? I usually look on the 12 volt sub wiring wizard and I usually hook my subs up together in the box like it shows. I'm just a little confused since usually I hook them up in them up in box and only run one positive/negative to the amp. I would usually check these with a DMM but I left mine the lake house.
Juicemane
Juicemane
Plano, TX
Juicemane
