Quick help: Pioneer amplifier (good or not?)
Slaugh
CarAudio.com Moron
hey, im interested in acquiring this amplifier.. what do you guys know about it???
is it good for running 2 subwoofers @ 4ohms on each bridge?
link: http://www.pioneerelectronics.ca/pna/product/detail/0,,32171715_32249715_35043053,00.html
specs
Poder contínuo (20Hz-20kHz, 0.08% THD)
4 ch: (4 ohms) 30Wx4
4 ch: (2 ohms) 35Wx4
2 ch: (4 ohms) 70Wx2
Poder máximo (EIAJ)
4 ch: (4 ohms) 60Wx4
2 ch: (4 ohms) 140Wx2
Resposta de freqüência: 10Hz - 50kHz (0, - 1dB)
Distorção Harmonic total: 0.008% (1kHz, 4 ohms)
Relação Signal-to-Noise: 108dB (IHF-A tornado mais pesado, em 1kHz)
Dimensões: 8-1/8 " x 2 " x 10-5/8 "
Características
Bridgeable 2/3/4 de potencialidade da canaleta
Uma operação High-Current de 2 ohms
Fonte de alimentação do MOSFET de PWM
Circuito de entrada equilibrado do isolador
Poder Screw-Type/terminais à terra
Terminais Screw-Type do altofalante
Entradas de RCA (x2)
Controle do nível de entrada de Hi-Volt (400mV-4V)
Cruzamento selecionável: 80Hz, -18dB/oct. LPF (A Ch.), 80Hz, -12dB/oct. HPF (A, B Ch.)
Impulso baixo (60Hz, 0 a +12dB)
FUSE DE 25A.
sorry for the specs in portuguese btw
Slaugh
CarAudio.com Moron
Slaugh
São Paulo, Brazil
ultimate157
