quick explanation of...
he has 22 posts jack -- i doubt he knows what a sticky is yet //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
lol come on, dont be harsh now... i got 2700+ posts on a non-car audio related messageboard.
i should know better to begin w/. i was looking up 'dual four' w/ no luck instead of wiring configurations.
lol didn't mean to sound harsh bro. you'd be real suprised about some of the ppl on here thats all good luck with your install let us know if you need anymore help.
na, i understand, id be the same if i were you
im exactly like that when ppl ask repetitively the same questions on the car forums. its frustrating.
i just wasnt searching correctly
thnx for the input tho
If you wanted a 2 ohm final load from a pair of subwoofers, you'd need two 4 ohm loads wired in parallel or two 1 ohm loads wired in series ...
Your options would be:
Two DVC 8 ohm subs (Parallel-Parallel)
Two SVC 4 ohm subs (Parallel)
Two DVC 2 ohm subs (Series-Parallel or Parallel-Series)
Two SVC 1 ohm subs (Series)
Two DVC 0.5 ohm subs (Series-Series) (Don't exist to my knowledge, though)
wtf is series-series, or is that what u mean...not sure if u meant if its possible or it doesnt even have a chance of being a reality
well in this case...
should i run 2 dual 4's for 1ohm
or 2 dual 2's for 2ohm.
i know 2ohm would be 'safer' persay, but what would you opt for?
2 12" se's or 2 130v.2's ran most likely through a nine.1 or a hifonics 1500d( yea, yea i know about their quality, but its all i can afford in my price range)... is what im debating
is running 1ohm going to be at more of a risk?
You want a final impedance that will get the maximum output from your amplifier. It would **** to pay for a 1000 watt amp but only get 500 watts out of it due to not wiring your subs to the amp's lowest impedance.
So to answer your question, it depends on the amplifier being used.
norcalSRTrida
norcal209
norcalSRTrida
Tracy, Ca
squeak9798
