Quick distro block help....
Down
This is what I'm looking for. I need a distro block with 1 1/0 in, and 2 1/0 out, I dont care what type of fuse it takes, has to be at least 100a. It has to have a volt read out, and of course I want it to look nice because its going on a nice amp rack. I also want a matching ground distro block, I'm looking at Tsunami and all these other brands, ebay, ect. Can anyone offer me some help?
-Down
sounds like a bad idea to me... if you split the o gauge into 2 you probably should go to 4 gauge wire...
also what I would do:
buy a O AWG " T " , stinger sells them, then fuse the seperate lines to the amps...and of course the main line.
The power distro block has to have 2 1/0g outputs because I'm using 2 amplifiers that has 1/0g inputs, so I'm trying to do this right the first time. Instead of fusing them at the lines to the amps, I want a digital distro block along with a matching ground block......
-Down
-Down
understood... forgive my newbieness...
-Down
probably be better to have 2 runs of 0 guage to your amps.
A distribution block, distributes power, it doesn't create it. You can't magically split a wire into two wires of the same gauge and expect them to both have the power of the original wire.
Down
Down
SA,TX
spoonraker
NorthFramingham
    Jun 30, 2026
