Quick Big 3 Question
Just run a good battery - to chassis. In addition, you can run a couple different engine to chassis grounds/ ***** to chassis grounds and it won't hurt anything.
Ok. I did alt + to battery +, battery - to chassis, alt bracket to chassis, and alt bracket to battery -. Is this correct?
Ok. I did alt + to battery +' date=' battery - to chassis, alt bracket to chassis, and alt bracket to battery -. Is this correct?[/quote']
That's fine. You didn't need to run the alt bracket to battery -, just to the chassis would have been fine, but it won't hurt.
there is already a fuse between the alt pos an battery pos. i bbypassed the fuse box. is alt bracket to battery neg then battery neg to chassis ok? instead of alt bracket to chassis then battery neg to chassis. i have a ground run also.
You do not need an alt bracket to -batt.
All you need is
ALT + to BATT +
BATT - to Chassis
Engine/Transmission block to chassis
just look for existing wires it's a really simple concept all you're doing is replacing the grounds, and adding an extra alt to batt +
Crownvicon28s
God 1st
Crownvicon28s
Spartanburg, SC
Crownvicon28s
