Question...
Well... not sure about box yet. but was thinking about gettin a Hifonic 1500D. so lets say 600 to each sub. if i did go that route. just wondering if it would be louder then the 12inch SX.
I've Seen ohms Digrams how to set up woofers. but never really understood them. only know how to set them up into 4ohms... for 1ohms do you wire both subs into one terminal or how does that work. and wouldnt 1500 rms to each sub be too much. or did i miss read what you said? lol.
The coils on each driver have a specific resistance, measured in ohms. When wired a certain way, that resistance across the coil is cut in half, wired another way it is doubled.
Example/
Parallel = /2
Series = *2
Two SVC 4ohm subs wired in parallel makes a final 2ohm resistance
Wired in series they produce 8ohms resistance
Two DVC 4ohm subs wired in parallel/parallel (the VC's on each sub wired in parallel and then the two subs wired together in parallel) produces a final load of 1ohm. 4/2=2, 2/2=1
Wired all in series would produce a 16ohm load. 4*2=8, 8*2=16
Help at all?
Hugebass
Hugebass
Milton Florida
RandyJ
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
