The box i just bought has 4 holes. it only has two positive negative outs on the box one on each side (dont know what it is called) i want to run two subs off each amp ( i have two amps) if i run the both the wires from the subs on each side right from those outs will the one amp be powering two subs or will both amps be powering all of the subs? i will put up a picture. if both amps will be powering all for can i take speaker wire and run it right from the sub to the amp or i should use the outs on the box?
