question
MikeCole89
The box i just bought has 4 holes. it only has two positive negative outs on the box one on each side (dont know what it is called) i want to run two subs off each amp ( i have two amps) if i run the both the wires from the subs on each side right from those outs will the one amp be powering two subs or will both amps be powering all of the subs? i will put up a picture. if both amps will be powering all for can i take speaker wire and run it right from the sub to the amp or i should use the outs on the box?
Model T5515-44 T5515-04
Description 15" Subwoofer 15" Subwoofer
Impedance Dual 4 Ω 4 Ω
RMS Power (Watts) 300 300
Rec. RMS Amplifier
Power (Watts) 150 - 300 150 - 300
Sensitivity 93.57dB 90.75dB
Voice Coil 2" 2"
Magnet Weight (oz.) 81 81
Mounting Depth 7-9/16" 7-9/16"
Cut Out Diameter 13-7/8" 13-7/8"
Sealed Enclosure Net Volume 1.75ft3 1.75ft3
Vented Enclosure Net Volume 2.48ft3 2.48ft3
Volume Displacement (SD x XMAX) (in3) 71.68 71.68
Tuning Frequency 38Hz 38Hz
well luck for you the amp will still put out 500 at a 4 ohm load. Wire the subs to 4 ohms. the loest the amp will take is 1.3 and it clips like a MF at that. So, just wire it to 4 ohms and you will be all set.
HAHA i think i blew one of my subs though bad smell =\ turned it down checked it out maybe just the voice coil?? even if so i paid 100 bucks for both on ebay would it be worth it fix the voice coil or just upgrade to the 7500's for $100 a piece?
MikeCole89
MikeCole89
Connecticut
MikeCole89
