Question with kinetik 3800Hc
The amp hours is the storage of the battery. If it says 135 Amp hours that means it can release 135 amps for one hour, or 270 amps for half an hour, or 66.5 amps for two hours without being charged if it starts from fully charged. If you calculate watts as being volts times amps, 12 volts times 135 amps means that the battery could put out 1620 watts for one hour without being charged. That's what the battery would put out, not how much amplifier power it could run because I'm sure you know that amps don't run at 100% efficiency. So if the amp runs at 80% efficiency then you could put out 80% of 1620 which would be 1296 watts for one hour without charging the battery. You'd also have to subtract the power the head unit needs to run and such, but I'm sure you get the picture.
Thanks alot that was so clear, and helpful I'd give you a hug if you where hear
chase007
Master Spammer & B.Ser
chase007
Grand Cayman Islands
chase007
