Question!! please help
maritoze
Jedi Master
340
CA
Ok so heres the thing Im plannin on purchasing a headunit, but i have a stock 6 disc cd changer. Will the CD changer still be able to connect to the new Headunit. I'm most likely going to get an Alpine headunit if that helps. Thanks
Alpine does do a wire connect that may work its for a cd changer itself i used mine for a dvd tuner in the glovebox and then to main deck ill send you a link and pick
http://www.mobileelectronics.com.au/store/index.php?act=viewProd&productId=15
and the pick is at the bottom it supposed to work for most things that run rcas and pin plugs otherwise there is another place called Audio xtra here in oz that sells pin to pin plugs that will fit specific make and model stake to apline or pioneeer etchope this helps dude //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
Thanks man I really appreciate it.//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif:)
maritoze
Jedi Master
maritoze
CA
maritoze
