question on wire
You can always use bigger wire than you need. It won't hurt anything. It will probably cost a bit more but the bigger wire is already run in the event that you want to upgrade and you won't have to throw out the initial wiring when you NEED bigger. In the long run, it will save you money to run the biggest wire you think that you might ever need the first time.
sharebear
Registered User
sharebear
here
smd4life
