Question on 4 ohm s10L7s
With 3 4ohm dual vc subs your options are
2.66 ohms
or
.66
You might be able to pull off the .66 with the imp rise that could bring you up to 1 ohm...correct me if I'm wrong.... or you could wire them to the 2.66 which is almost 3 ohm. So either way you want an amp that will put out the comined RMS of those subs which is 1500 watts and tehn some.
It is 1500 watts @ 2ohm and your set-up will be closer to 3 ohm. I assume that the 3 ohm setup would be in the middle even though it is not listed. But like many have said before this is an estimate and you will likely be around 1000-1500 watts running around 13.8 volts which would be perfect.
750 watts 4ohm
1000 watts 3ohm
1500 watts 2ohm
Horsekegger
Horsekegger
Helena MT
denim
