question for torque convertor pros
dbhittin
Banned
7,142
Van...Wa
my dads truck, 01? ford F150 with the 5.4 V8, when i push the peddle all the way down and the rpms go up, it wont change gears for like 2secs and even if i let off the gas, it still stays reved up for a bit before it kicks into a diff. gear. so basically its really slow at changing gears
So what do you want to know whats causing the problem? Sounds like a couple different things Try adjusting your shifter linkage, that could help. Or the big possiblility is that the torque converter is slipping. Sometimes a shift kit or valve body upgrade will cure the slow shifting problem. The shift kit will adjust the shift points and make it more crisp or softer depending on what you want. But for a 2001 that doesn't seem normal unless the truck gets abused for towing or has a lot of other abuse on it.
trans is slipping. check your TC. maybe its just loose from the company...
fords have a tendency to stutter before shifting.. atleast in the 4.6 trucks i've got 3 friends with em.. and u mash the gas.. and it'll raise the r's for a second and then shift and go
They going for a fair bit more now...I wanted one for my delta but didn't wanna pay the price for old caps 😂
94
592
Nothing to add to this, Just wanted to say good luck and that I miss MiniDisc. OH!! Is that a Japanese Radio Tuner or does it get stations in the US?
876
dbhittin
Banned
dbhittin
Van...Wa
monte_carlo97
    May 24, 2024
    May 23, 2024
