Question for smart ppl! help me plz
CrazyKenKid
hey guys i have a question. i have purchased a orion remote gain control. and thhere is an red LED light which lights up and it says it wnats a 12v hook up. what i was wonderign is hwo can i hook this up? would it be easier to hook it up to a batterie pack a 12v batterie pack? but i don't know will this work? or what else cna i hook it up to. it also requires a ground.
thanks
Why wouldnt you just rob from one of the larger fuses in the panel in the interior of your car(glovebox etc...). They make a female connected that attaches to one of the teeth on the fuse. Then find any suitable ground. I have my remote knob in the center console of my truck and there are several suitable grounding spots. Hope that helps and or makes sense.
o yes i never though of that! thanks i will have to give it a look to see if it is do able. i have a 95 grandam good thinikking thank you
umm ya i don't know. the knob turns on but the red led (backlight) doens't turn on unless you have that 12v current i am thinking. but really i don't know b/c i never had one of these to play around with.
if it doesn't turn on with the amp and needs it's own power, i would use a relay so you could run off your remote turn on and it would turn on with the amp. just my 2 cents.
CrazyKenKid
CrazyKenKid
Canada
CrazyKenKid
BP1Fanatic
BP1Fanatic
