question bout my system i want
atxmarine
ok i want to get 2 MA AUDIO HK120XC 12" COMPETITION SUBWOOFERs but im having trouble finding a amp for them does anyone have any suggestions to make my system run at its best they run with
Peak Power Handling: 1200 watts
RMS Power Handling: 600 watts
Impedance: 4 ohm
and also should i get a mono amp or a 2 channel
Any 1200W amp that is stable with the subs' impediance that you feel is reasonably within your budget. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif There's too many amps to list.. You'll have to be a little less vague.. Hope it helps narrow it down.
-Bill-
Examples.. If you wanted to run two amps, you would wire the subs parallel to present a 2-ohm load to each amp. The amp would then have to be able to put out 600W to one channel at 2-ohms. Such as this amp: MA Audio HK398
If you want to run 1 amp. You'd do the same thing as stated above.. Only this time, match the impediance for 2 channels with a 1200W rms amp. (2 X 600W @ 4-ohm)
That should help a little more than my first post. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
-Bill-
-Bill-
Try again.
He has two 4 ohm subwoofers that can take 600 watts rms.
You have 3 choices:
1) A mono amp. Wire the subs in parallel for a 2 ohm load. Now find an amp that puts out 1200 watts at 2 ohms.
2) 2 mono amps. Find a couple amps (identical) that push 600 watts at 4 ohms. This is probably going to be more expensive.
3) A single 2-channel amp. You actually have a couple choices here:
3a) Find an amp that is 2 ohm mono stable, or 1 ohm stereo stable. Same thing. It would have to put out 150 watts per channel at 4 ohms, for a combined 600 watts per channel at 1 ohm (estimated). It'd be hard to find an amp that does this, so you probably don't want to go this route.
3b) Find an amp that pushes 600 watts per channel at 4 ohms into 2 channels. This will also be kinda hard to find.
My suggestion would be stick with option 1. I was just giving you possible choices.
atxmarine
atxmarine
austin tx
XanderMoser
