question about wiring
could i just get a 4 gauge power wire and then hook that up i dont need anything that long because my battery is in my trunk because i have a cobalt. but do you think if i get the power wire it wont pop the fuse? and im in youngstown ohio
if you get the correct fuse, it won't pop the fuse
They've already figured out the problem, but look at this link and tell me what voice coil wiring option you have.http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=2&woofer_imp=3
Are your subs dual 2 or 4 ohm? Do you have a link or model number of your amp?
They've already figured out the problem, but look at this link and tell me what voice coil wiring option you have.http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=2&woofer_imp=3Are your subs dual 2 or 4 ohm? Do you have a link or model number of your amp?
i have the wiring option number two
the model number to the amp is MTX 8502 thunder 2 channel amplifier
and the subs are 2 ohm DVC
alwaysontop
alwaysontop
Ohio
alwaysontop
